2006 Apex wont start
johnketch
Laingsburg, Mi,
when i turn on the key the fuel pump prims but when i turn the key to crank NOTHING silence
what could be the problem? relay?
Id check the relays first on the left side of the sled.... also check the ignition relay near the battery.
X2 on the relay next to the battery they get coroded inside and fail new updated version wont it is sealed better had the same issu on my 07.
What dose the relay look like
a selonoid the hot wire from the battery is attached to it.
with red wire attached.
right next to the two green relays in your pic. has one thick wire from the batery and one going to the starter and the little signal wires.
There has been issues with the connector between the two red 10amp fuses on the soleniod. Water can collect on the connector and corrode it. Clean it up and pack it with some dielectric grease.
There is a good write on this somewhere in the forums but I can't find it right now.
LPS3 works fantastic for electrical connections and it comes in a spray can. It leaves a soft waxy coating that displaces water,it is also an anti-corrosive. It won't freeze and won't fly off, the only downside is it is a little pricey.
When I worked in the sign industry years ago we used it on all electrical connections on installations by the ocean. It was the only stuff we ever used that would last a few years. The ocean environment would literally eat transformers and wiring but the connections with the LPS3 would still be good.
