Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
I have 2006 Attak with 35000 km. It broke down last year on the trail and got it back to garage it started again. I just changed the oil and now I got a code 12 for the crank sensor. I tried the black plug and had no ohms readings. Can I just replace the sensor box or do I have to change stator too?
RobX-1
- Coldwater, OH
Guys wanting to save money have opted to just replace the sensor as Yamaha only offers the sensor with the complete stator assembly; cannot purchase just the sensor from Yamaha. When my sensor went out, I replaced with OEM stator but have read guys have had success with replacing the sensor too. Travis of Barn of Parts has just the sensor if you choose to go that route.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Of you want to order it from inside Canada check out RM Stator in Quebec, they offer just the pickup coil for replacement without the entire stator.
Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
So do you connect it inside the cover or outside ?
you need to pull the cover off to replace the crank sensor or the stator. make sure you get a gasket before you tear it apart as they do tear when taking them apart. i went oe on the phazer i did as no one could tell me how long the aftermarket ones last.
Warp
- Apr 12, 2007
- Corner Brook
- 2006 Attak
Yes thanks , do you know what the ohms is on a good stator
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Yamaha Apex 2007 no sign off life
Its called a crank position error but the problem is the stator pickup coil and it could be the stator itself. You can eliminate the pickup coil by measuring the resistance through the coil. It should be 446 ~ 545 Ω at 20°C (68°F) (White/Red – White/Green). If the pickup coil is bad, rm...
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Amazing what you can find using the search function eh?Yamaha Apex 2007 no sign off life
Its called a crank position error but the problem is the stator pickup coil and it could be the stator itself. You can eliminate the pickup coil by measuring the resistance through the coil. It should be 446 ~ 545 Ω at 20°C (68°F) (White/Red – White/Green). If the pickup coil is bad, rm...ty4stroke.com
It should be a 500ohms pickup coil.Yes thanks , do you know what the ohms is on a good stator
If this were my sled, I would remove the stator and visually inspect it. When they start to darken in color, that's not what you want to see.
