This weekend my wife was riding down the trail and her attak just quite and code 46 came up and sled would not start......the fuel pump would run but when you turn the key the starter would not engage. The manual says for code 46 - Vehicle system power supply (Monitor voltage). Has anyone ever run into this and if so what was the prob? I'm thinking ground blocks since the starter doesn't even turn the engine over. If anyone has any info for me that would be great.
Check the white connector near the battery on the inside of the frame near the oil tank. It seems a few people here have had a problem with corrosion on that connector.
