2006 attak handle bar riser question
grizzerly
Hillsdale, Ontario
How much riser can be added before replacing throttle cable and if lengthen throttle cable how much higher can you go before replacing another cable or line?
I installed the two inch Rox rizor. No trouble, This is perfect for sit or stand. Much taller and you will be reaching up when sitting down.
I installed an 8" Powermadd riser plus a 1.25" pivot adapter which equals 9.25" of riser...so whatever you do you will be fine!
If anything...follow the cables and look for some slack...you will find it. I didn't have a problem
3.5" Rox Riser is a big as you can go. No problems with over 1,500 miles on my riser.
