grizzerly
How much riser can be added before replacing throttle cable and if lengthen throttle cable how much higher can you go before replacing another cable or line?
Honk
I installed the two inch Rox rizor. No trouble, This is perfect for sit or stand. Much taller and you will be reaching up when sitting down.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
I guess that depends on how tall u are.
Yamaha Man
I installed an 8" Powermadd riser plus a 1.25" pivot adapter which equals 9.25" of riser...so whatever you do you will be fine!
If anything...follow the cables and look for some slack...you will find it. I didn't have a problem
RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
3.5" Rox Riser is a big as you can go. No problems with over 1,500 miles on my riser.
