wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
Does anyone know the stock rear spring on the Attak and what there are for options going up? I have a buddy that is a bigger guy and his sled is always squatting. The shock is good, it seems the spring is weak.
Thanks.
Thanks.
Standard is a 49Nm. Optional was a 69Nm
I installed a Pioneer Perf 6.5 on my Attak.
kramerica72
- Mar 27, 2015
- Fremont, NH
- 2006 Attak, Phazer 500, XCR 800
Pioneer sold a 7.0 and 8.0 as well. I just put the 7.0 on mine but haven't tried it yet.
6.5 kg/mm PP-8FU-891
7.0 kg/mm PP-8FT-891
8.0 kg/mm PP-8FU-893
Here are Yamaha part numbers--probably more helpful:
8FU-47489-10-00 SPRING 1 (6.5Kg)
8FT-47489-10-00 SPRING 1 (7.0Kg)
8FU-47489-30-00 SPRING 1 (8.0Kg)
Barn of Parts has new multi rate springs, FYI.
wavemaster
- Mar 6, 2009
- New Hampshire
Thanks guys. He is going to go with the stiffer spring and lower pre-load. It should help out a lot.
