Captainjmiller
- Dec 29, 2019
- Newark, NY
- 2006 Yamaha RS Venture
I have an 06 RS Venture with a dead battery. This is my first Yamaha so I'm guessing from looking at it that the battery is buried in the middle of the engine compartment underneath the air box? I was just wondering how hard of a job is it to get to the battery to change it?
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Welcome to this site. I changed the battery on my 2016 Vector recently. According to everybody on here should be the same Delta box chassis. All I had to do was remove the air box. Battery was under a plastic cover held on by a rubber strap. You will find this site very helpful. Best Snowmobile forum I have ever been on!
Metallicat
Yes, not a bad job at all especially on the older style sleds with the flip up hood. A battery tender, reconditioner isn't a bad idea for storage
Captainjmiller
- Dec 29, 2019
- Newark, NY
Thanks for the info guys. I'll be taking a crack at it this weekend.
Steve Raymond
- Feb 3, 2020
- Northern Ontario
- 05 rs Venture
Did a battery change fix everything?
Captainjmiller
- Dec 29, 2019
- Newark, NY
I was able to get the battery changed pretty easily but it's still not starting up. I ended changing out the plugs and it's still not firing up.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Good gas in it?
was it running before the battery died?
does it fire on quick start or brake cleaner (flammable one)?
those where bad for plugging the pilot jets when they where not run enough and emptying the bowls on the carbs.
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Is it cranking?
Did you try crossing out the starting solenoid? Does it start then?
