Harvey Lunnen
Replaced spark plugs and battery started perfect. Left outside for a week cranks over fine won't start.
Any suggestions?
			Any suggestions?
WANN4STROKE
 - Feb 26, 2007
 - Anchorage, Ak.
 - 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
Spray the carbs with a silicone spray.  What I do after mine has set for a while.  Better than starting fluid.
			BACK COUNTRY YAMAHA
 - Nov 26, 2015
 - newfoundland
 - 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
Was your machine stored properly over the summer ie: fuel stabilizer or carbs drained,   If not you are probably going to need your carbs removed and cleaned then synchronized! This is a must for carbed  2 or 4 stroke engines,   more so for 4 strokes do to the machine can run very rich to a point where it will fill the base with fuel resulting in engine damage!
			dragerman
 - Mar 15, 2014
 - Red Lake, Ontario CANADA
 - 2014 VK Pro
2011 VK 540III
Sometimes it can loose its prime when sitting for a while, try taking the air filter off so you expose the crab intakes and put a drop of fuel down each cylinder then try and start.  Good luck
throw a boost pack on it and try a full synthetic oil change.  helps it crank faster.  might have to pressureise the vent line on the fuel tank to get it to prime again as that motor like to bleed back when not run enough.
			YukonMP
 - Dec 25, 2014
 - Yukon Territory
