I have a 2007 Apex GT that won't fire up. Its been sitting for over two years. I replaced the fuel, new plugs and added some sea foam to the gas. If I squirt a bit of Starting Fluid it will fire for a second but wont run. Any ideas? Thanks in advance.
If it fires with starting fluid it's not the ecm shutting
it down. You are just not getting gas. Make sure your
injector pump is working (fuel pump) and keep trying.
Go easy on the starting fluid, not good for motors
in large quantities.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Take the airbox off and squirt fuel down the intakes and lay off the starter fluid. I dries out the cylinders and then there is no lube on the cyl walls thus no ring seal. Also sounds to me like its not getting fuel.
cat hunter
X2TBay Sledhead said:Take the airbox off and squirt fuel down the intakes and lay off the starter fluid. I dries out the cylinders and then there is no lube on the cyl walls thus no ring seal. Also sounds to me like its not getting fuel.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
How about the battary, thinking its low.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
X3
Battery is good. Took the airbox completely off and used gas in the throttle bodies. Runs off that but still wont pull fuel. Any way to test the pump? How about a fuel filter?
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Can you hear the fuel pump running. When you turn the key on you should be able to feel one of the relays above the left footwell click and hear the pump running.
Fuel pump is not comint on. I checked the relay and that is worknig.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Check the wires to the pump under the seat.
I've heard of critters chewing them there. You also can check for power to the pump while you are there.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
if u got power to the pump and it isnt running u need a pump.
