2007 Apex RTX setup
front shox 65 psi, limiter strap second to last,weight tranfer first line and rear shox half turned in and the sled rox pretty fine man.
I like my floats set between 60-65. I find much less than that and they start to bottom out or at least feel too firm (I ride aggressively).
I also tightened the front limiter strap 1-2 holes, rearched the rear torsion springs to let me work more of the suspension (making it sit ~4-5" taller).
I run the main shock clicker between 0-1 click from full hard. Full hard when I'm riding very rough trails and 1 click away for more typical riding. Even with the shock on full hard, the torsion springs cranked right up and anti-bottomers installed it still bottoms out, but only on the biggest bumps. Note with the shock on full hard, the stutter bump performance is terrible (like riding a dump truck over 1" bumps when unloaded).
I will be revalving the skid shocks, but with the fresh snow I can't seem to find the time....sledding is more fun than wrenching.
