bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
Guys
my Apex starts to vibrate at 70 mph and I can seem to figure out where to start I have looked at springs bearings and nothing ?? any ideas where else to look ?
dave
dave
philchy
- Jan 3, 2013
- PLOVER, WI
- 2015 SR VIPER RTX-DX, 2008 APEX GT 40TH ANIVERSARY, 2008 VECTOR GT 4OTH ANIVERSARY,2008 VENTURE GT, 2012 VECTOR RS, 2011 VECTOR GT,2003 RX1
Track ripped/ torn? Studs missing?
philchy
- Jan 3, 2013
- PLOVER, WI
Secondary clutch bearing directly behind clutch?
Winderallday!
Check speedo bearing on drive axle, drive belt could be starting to de-laminate, check for missing track clips, check chain tension.
bigdave
- Dec 18, 2003
thanks guys a ton, Ill dive in to it tonight and report back if I find something.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Change your Belt first !
1moretime
Slides could be worn.
My 07 Attak was doing that at high speeds. The washers on the rear axle had worn groves into my rails. The tension bolts would only tighten so far and then stripped. Not sure how many miles you have but mine started when the W arm cracked and other suspension components took up the stress.Guys
dave
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
CHECK BELT, SOMETIMES THE SIMPLEST THINGS WILL FIX ISSUE
check the belt. usually the culprit on my sled.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Belt, had it happen to me.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Belt
maxdlx
I say belt. Just saying
CaptCaper
- Jan 1, 2007
- Northern N.H.
I have had ice build up.. do it.. I bring it in and thaw it out.. do this so much.. runs like a new sled after.
icebreaker
BELTGuys
dave
- 7K
