BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Found a guy parting out an attack and has the Ohlins for it. Was wondering if they are a simple swap in or is the front end different on the mountains? He lists them as ohlin front shocks 17.5” open and approx 13” closed if that makes a difference.
He also has rear ohlin with big boy spring, I"m guessing it won't fit but maybe someone here would know for sure.
Thanks!
Thanks!
mtx apex has shorter shocks than the standard apex/attack. if you do like my brother and put the trail front end on then they will fit.
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Thanks !
Dont think im going through all that to mount a used pair of shocks though just going to pass on them.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Mountain sleds have a narrower front end, those shocks would be to long.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
He is also mistaken on his measurements. Stock Ohlins are 16.5" CTC and MTX shocks are 15.5" CTC. You can use MTX shocks on Trail sleds and vice versa just understand how it screws up the OEM parallelogram of track and skis. I have had both and experienced the effects. If you put them on your MTX it would give you more front end height and possibly make the sled trench a little more and add ski pressure. If you remounted the rear suspension to compensate then it would fix that but raise your COG so the sled may be tippy in the deep. So it depends what you are after.
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Thanks. He wanted way too much for the imo anyway.
Maybe set of floats down the road, save some weight. Skis usually in the air anyway lol. Or maybe different rear skid first if I come across a decent deal.
- 6K
- 52K
