Shanevk
- Nov 4, 2017
- Edmonton
- 2007 Vk 1000
Hi guys,
I've seen a few pictures of VKs pulling large loads and wanted to get opinions on my VK's ability to pull an ice skid. I am having a ice fishing shack built out of aluminium and will weigh roughly 1000lbs with all the equipment in it. The skis are covered in HDPE so it should glide pretty good. Was wondering if this sort of weight would be hard on my 2007 VK 1000? Trips might be upwards of 20 miles into some lakes.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
If you runt the sled in low gear, there will be no problem at all. Maybe you should stud your track thou. You have those studs that you screw in to the lugs that could be very effective on the ice.
And if you run on hard packed/ice a lot you can wire your radiator fan to run all the time to prevent over heating.
Shanevk
- Nov 4, 2017
- Edmonton
- 2007 Vk 1000
Ok, what speed can I expect to get out of low gear? Would it pull it in high gear?
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I would go in low gear in the terrain and maybe high on the ice. I would not go any faster than 30 km/h in low gear. If you could go that fast, then high gear is more suitable.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
FYI I have a used auxiliary rad and fan that I pulled off a vk. It gets plumbed in series with existing radiator. Was a Yamaha option.
