RobX-1
- Coldwater, OH
The exhaust cam has two dimples at the end and the intake has one.
PETETY1968
- Jun 7, 2022
- FLINT
- 2009 Yamaha NYTRO XTX
2998 ARCTIC CAT F1000
2007 YAMAHA VECTOR
both cams have only 1 ring. I did notice that on other models, does not apply to mine. Thank you for responding. I believe after looking at my pictures that I have it correctly installed.I recall reading about the differences between the exhaust/intake cams in this post. Something about the intake cam having/being a single ring and the exhaust cam having/being a double ring. Not sure if applicable or not but might be something similar to distinguish between the two.
PETETY1968
- Jun 7, 2022
- FLINT
2007 YAMAHA VECTOR
DIMPLES? on the very end of the cam or on the lobe area?
PETETY1968
- Jun 7, 2022
- FLINT
2007 YAMAHA VECTOR
Can you tell me if the dimples you are referring to are on the gear end or the opposite end and are they indeed on the very end or the surface where the lobes are?The exhaust cam has two dimples at the end and the intake has one.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
According to the OEM parts diagram, the intake and exhaust cams are the same.
I'm looking at a 16 1049 so it may be different.Can you tell me if the dimples you are referring to are on the gear end or the opposite end and are they indeed on the very end or the surface where the lobes are?
- 7K
