w8nfsnow
09 Nytro XTX.........128mph in approx 1300' on ice. I'm running an McXpress Turbo in full trail mode. Now I need a set of extrovert drivers because the stock drivers just can't take the power.
SledFreak
- Feb 7, 2005
- Ontario. Canada
billymx815 said:SledFreak said:Did 114 today on plowed road, but it had 3-4" of fluff on it, so it was holding me back at bit. It's got more yet...
115mph is my goal number...What mods do you have?
Same as you, but Full Excell system
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
SledFreak said:billymx815 said:SledFreak said:Did 114 today on plowed road, but it had 3-4" of fluff on it, so it was holding me back at bit. It's got more yet...
How many miles on your sled? Maybe I should wait till i'm broken in before assuming I wont be at the 9200rpm range...
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
w8nfsnow said:09 Nytro XTX.........128mph in approx 1300' on ice. I'm running an McXpress Turbo in full trail mode. Now I need a set of extrovert drivers because the stock drivers just can't take the power.
Nice speed there eh! I know we can get alot more out of these Nytros going turbo but that's not an option for everyone (expensive)...
SledFreak
- Feb 7, 2005
- Ontario. Canada
1100 miles.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
SledFreak said:1100 miles.
How many miles do you consider a sled broken in? I've heard as little as 1st 150miles to as much as 1500miles. I tend to believe its on the lower side because of the quality and tight tolerances in todays engine production...But
for sure.SledFreak
- Feb 7, 2005
- Ontario. Canada
billymx815 said:SledFreak said:1100 miles.
How many miles do you consider a sled broken in? I've heard as little as 1st 150miles to as much as 1500miles. I tend to believe its on the lower side because of the quality and tight tolerances in todays engine production...Butfor sure.
IMO, these engines really 2000+ to see full potential. You will notice a difference @the 100-300 mile mark as far as RPM is concerned. At the 1000-1200 miles mark, you will notice it to be alot faster on top end, then it was at 300 miles, but I believe that is really the chassis breakin in. At 2000+ miles is where the motor seems to be good and loose.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
Thanks SledFreak...I wouldn't have guessed that high. I'm going to wait then before screwing with clutch & gears to see what I've got. On a short WOT I've got 106mph gps and there's more in there...I think! Don't no if there is 115mph but will see...Of course I am a fat
(250lbs) w/gear so maybe a cheap mod would be to shave 10-20lbs of the rider...LMAO
(250lbs) w/gear so maybe a cheap mod would be to shave 10-20lbs of the rider...LMAODaranello
Suspended
Wiked...GPS or Speedo....cant wait to try my sled out....been busy here
SledFreak
- Feb 7, 2005
- Ontario. Canada
Daranello said:SledFreak said:Did 114 today on plowed road, but it had 3-4" of fluff on it, so it was holding me back at bit. It's got more yet...
GPS 110... But, I will tell you this, that I ran side by side with my buddies D&D ported/head/pipe/y-pipe/air intake/bookdocker/clutched with 1" track and 202 1.450 studs to my 114 studs. Starting at a roll on @30-40mph and we were dead even until we both let off @114 because we were both starting to get sucked into a snow bank on each side of the road. I will note that his drivers were skipping when at the beginning of the race and he said at around 80mph (which I thought was weird), but the Nytro was dead even and actually ahead by a ski loop. Like I said we were pushing 3" of powder on the road, which was causing the track to lift and float the sled. I would like to race him from a dead stop with a few adjustments to the suspension, because that is where the Nytro shines. I know he will beat me on top end, but I believe it will be closer then he thinks.... We raced probably 1/2 a mile...
P.S. I still think I can tweak my clutching some more to get it better..
Daranello
Suspended
SledFreak said:Daranello said:SledFreak said:Did 114 today on plowed road, but it had 3-4" of fluff on it, so it was holding me back at bit. It's got more yet...
That the same speeds I was getting last year...............
NoW this year with my MODS and 50lbs weight lost>>>I cant wait to see what this baby will do
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
Daranello...you'll probably bounce the rev limiter now...coooool
SledFreak
- Feb 7, 2005
- Ontario. Canada
Daranello said:SledFreak said:Daranello said:SledFreak said:Did 114 today on plowed road, but it had 3-4" of fluff on it, so it was holding me back at bit. It's got more yet...
Daranello, My sleds hauls good, and I know there is more in it for top end, but I'm not sure if it's much more then what you got last year. I think I can pull 115 on GPS, which will be about 120 on the speedo... I believe though you will have to be really good with the clutches to get the big number you are looking for. But I will tell you it's gets to top end in a hurry....
SledFreak
- Feb 7, 2005
- Ontario. Canada
Rayman5271 said:Rain and 35+ temps made the past two weeks interesting. After getting the lake to drain and back in good condition... testing continued. I'm finding that the nytros are a lot more different than expected. I have been testing setups on two different nytros, that are identical besides exhaust manufacturers and I am seeing crazy differences. Putting these D&F weights on a sled and running any proven setup works, but in order to really take advantage of these weights you must find what your sled likes and secondary clutching to match it. I have been running trail setups and am seeing 114-115gps consistently on the ice track, I think this is the wall I was hoping to hit... if anyone finds similar or better results let me know and we can compare clutching... time to ride.
Rayman, what is your setup you are using for your D&F's?
HOMEHARDWARE65
98 mph on speedo so far. still climbin, but had to slow down cuz i didnt want to run out of road. can't wait till the summer to go to schmidt bros clutch kit and play with the gearing
