wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Looking to buy 2009 Apex GT. How do you adjus the shock on the fly for the suspension ? Salesman says you have to adjust under the sled. Used to be a switch on dash but I dont see one.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Left thumb control on the handle bars.
wkeggenhoff
- Dec 20, 2007
IS THAT NOT FOR THE HEATED GRIPS ?
You must switch the mode to suspension on the cluster. Then, switch back the mode for warmers.
wkeggenhoff
- Dec 20, 2007
thanks, too bad the salesman at the dealer did not know that
danq
There "is" an adjustment knob on the shock itself, in addition to the thumb switch. If I recall correctly the knob on the shock is rebound and the electric adjustment is compression.
Super Sled
- Feb 25, 2009
- Summit X
wkeggenhoff said:thanks, too bad the salesman at the dealer did not know that
Sounds like a knowledgeable salesman!!!!!!!
