Corisian
- Dec 16, 2009
I've spent some time on the site looking for this answer and may have overlooked it. On my 09' MTX the dealor had the front limiter straps bolt in to the 4th. hole from the bottom (3 holes showing empty). The straps seem very loose when the machine is sitting flat on my shop floor. On my 02' 151" Viper and on my 2007 Phazer Mtn. the limiter straps are very tight when the machine is setting flat on floor. I'm seeing the quick hyfax wear and was curious where you all have your front limiter straps set at?
I'm going to double check the track tension and add some scratchers.
Many thanks on the limiter strap question.
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Mine are the same. I got 2300 kms out of my first set of slides. I use scratchers and put a marginal snow kit on this year.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Mine are the same. I got 2300 kms out of my first set of slides. I use scratchers and put a marginal snow kit on this year. I haven't changed them but would lilk to know if there is any other benifits for changing them.
