Shannon1984
- Feb 6, 2022
- Burin Peninsula
- 2009 Nytro MTX 153
I have a 2009 Nytro and I purchased a set or after market heated grips, I noticed the factory grips only have 2 wires and the new ones have 3 wires, Is it still possible to wire them into the factory harness and switch to get rid of code 81 or do I have to use the supplied switch and bypass the factory harness altogether?
radianguy
- Jan 1, 2007
I wired RSI 3 wire heaters on both of my sleds, along with a lot of others on this site. What brand did you go with? There were instructions on this site showing how to wire the RSI to factory wiring.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
RSI three wire high power grip heaters
Hi, need some help . Dealer sold me the wrong hand warmers. Crappy directions. White is high blue is low red is ground. It said when hooking up to a two wire OEM system you have to hook up red/ blue together to make a one wire system. All the wires are good tested lighting coil and yellow/ black...
ty4stroke.com
Shannon1984
- Feb 6, 2022
- Burin Peninsula
I purchased Maxx 12 v heated grips, I got them at a good price, I just went ahead and wired them together, both high and low wires together, they seem to be working fine, plus code 81 is no longer on, so far so goodI wired RSI 3 wire heaters on both of my sleds, along with a lot of others on this site. What brand did you go with? There were instructions on this site showing how to wire the RSI to factory wiring.
