Brentlav
- Mar 7, 2013
Hi,
Looking at a 2009 Nytro XTX with only 2000 miles but looks like it could have been 2000 hard
driven miles.
What should I look for and with all the talk of twisted front frame how can you tell from just looking at it?
Thanks in advance.
driven miles.
Thanks in advance.
gc_srt
Although I have never seen a bent sub frame, look at the skis and make sure one is not leading.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Ski spindle angles don't match one another, shocks touching A arms, even denting them, crinkled lower plate on the subframe, loose A arm bushings,one ski seems to stick out further than the other, etc.
There are a lot of threads on the weak subframe of the Nytro. Try the search feature...I've seen lots of pics posted by other members, myself included.
Lee Rivers 1
- Oct 18, 2014
- 2009 Nytro RTX
The shocks should be in the centre of the a-arms...mine is out a bit but does not effect the handling at all..if they are out a lot then there is a problem.
Brentlav
- Mar 7, 2013
Thanks a lot guys. Looks like I will be the proud new owner of a brand new to me 2009 Nytro XTX.Hi,
driven miles.
Thanks in advance.
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Make sure to update your fuel pump relay. Mine stranded me last year. Also check for wiring harness rub and perhaps starter solenoid. All easy fixes with Lots of info here on the site. Enjoy!Thanks a lot guys. Looks like I will be the proud new owner of a brand new to me 2009 Nytro XTX.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
welcome to the club....... a small bit of set-up and they're awesome
