dave carpenter
does anyone know if there is a difference between a 2009 Yamaha nytro xtx front lower arm and a 2012 Yamaha nytro xtx. The part numbers are different but I think it is just because of the year?
Dr. FeeLGooD
I think 12's have grease nipples in the uppers
dave carpenter
So do you know it the lowers are the same?
Dr. FeeLGooD
I think they are pretty much the same as long as both sleds are xtx. I bought a set of take offs for my 2009 but I don't recall if they are 2011 or 2012. If they come with the ball joint get the little spacers for the ball joint also because there is a little change up on that. If you bent your arm look to make sure the subframe isnt bent. It usually is but lots of info here about that. Good luck.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
2009 and 2012 XTX lower a-arms are interchangeable. The part# for a new arm includes the bushings and balljoint. The reason for the difference in numbers is due to the 2012 having the updated 3-piece ball joint. The 1-piece and 3-piece ball joints are also interchangeable.
