Tannyn Stumph
- Dec 16, 2019
- Stornoway
- 2010 yamaha nytro xtx
Hey guys. I need help. I recently bought a 2010 nytro with 6000km. Decided to do the spark plugs and oils. And go through it to make sure it was ready.
Part of this was I wanted to instal a teather. Now i dont know if this is what's causing the issue or not but in my opinion it is.
Now the problem is I have zero power.
No display.no relays clicking no nothing
I removed the teather all together and re connected the wire I spliced it into(brown killswitch wire)
I may have hooked up the teather wrong.
All the fuses by the brake were good. But I replaced them all. I also replaced load control relay. 12v at main fuse.Tested everything for 12v. Now I have 12v comming out of the starter relay. I have 12v at the ignition plug. But that's it.
If I fried something wtf is it??????
pull the teather off and see if it starts. might have the wrong type of teather. you need the one that is closed when the rubber is on instead of open when the rubber is on.
Tannyn Stumph
- Dec 16, 2019
- Stornoway
As I said. I removed the teather completely.
Would hooking this up wrong fry something other than a fuse?
Kill switch
Ignition
I figured a fuse should blow before anything else.
Kill switch
Ignition
have done this myself, kill switch not up?
Tannyn Stumph
- Dec 16, 2019
- Stornoway
It's been s week... its even up and down 100 times lol
radianguy
- Jan 1, 2007
Did you have the ignition uplugged? Try that connector if so.
- 6K
- 6K
