2010 phaser 12V power supply
2013zephyr
Toronto
Canada
2010 phazer
Want to hook up a GPS. Where can I get 12V that will only be powered up when the key is on. I see a 3 amp spare fuse with a brown wire out of the fuse box. I can't find the same wire elsewhere in the harness. Do want too cut the wire if possible. Any help would be appreciated. Thanks
Its been so long. I believe they have a plug upper left while sitting on it. Use it. Have seen people hook it up wrong and it causes the starter to run all the time. Guys help me out here please.
There should be a two prong plug to the left of the steering for an accessory socket. You could try to source an actual Yamaha accessory socket with the plug or just use a couple of spade connectors. IIRC, that's what is powered by that 3A fuse.
why not use rocks toyz power supply? gives you 2 usb chargers and 2 rca to run stuff from.
