snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Yamaha Sidewinder, Viper XTX Turbo, Apex SE, Vmax 4, SRX 700
- Farimont MN
Apex & xtx
tbey made that polaris look pretty slick to the eyes but i am sure they'll end up painting it full of tacky looking stickers but all black like that it looks nice
LazyBastard
From the front it looks just like a revxp, so we can presume that the engineering is of a similar quality.... tinfoil and paint. And that back suspension looks heavy and exceedingly complicated. If you look at that crazy red suspension frame, the upper rear wheels pivot back and up as the suspension compresses... no doubt to tighten the track in order to compensate for too flatly angled of a front main arm with respect to its length. They probably did it this way because their lawyers told them that if they made the front arm as long as it should be, they'd be infringing on expert/x.
horkn
If you look at the specs, it has a dragon sp front end, and a new rear suspension, witha new chassis and the 600 cleanfire 2, 2 stroke.
With a dry weight of 459lbs tells us that it is not a brittle light doo, but a well built polaris. Apparently it is a couple lbs lighter than a 600 dragon sp.
- 13K
