2010 Yamaha Venture GT Code 83 35
Code 85 is thumb warmer short cicuit and 35 is ignition coil on cylinder 3 is faulty.
Anytime I've come across multiple codes on these sleds it due to a wiring issue. I would inspect the ground splices above the fuse box. The splices look like a connector with a rubber cap on it and all the wires coming into it will have the same color code. Pull the rubber cap off and look for a burnt wire or bad metal splice across the top. Usually there will be some discoloration in the block if it's burnt.
It's also a good idea to check for a blown fuse and to check relays for corrosion, especially the starter relay.
