2011 nytro rtx skid plate
M-FACTOR said:
I use the Yamaha Ultra Plate, and have no complaints, however, i wish I would have seen this Roest plate before I bought. Makes me think. Nevertheless, Ultra plate has worked for me.
I use the Yamaha Ultra plate. It works. Enough said
VectorLTX2012 said:
Zakre said:
There are 6 bolts the two each side and the two in the front look closer and you can see them in the pics.
I definitely see the two in the front. I also see two on each side, but they look like they are on the under-body panel and not on the skid plate. Maybe I don't understand how the plate is held on or the design.
Chester
:jump:
:letsnow:
The two front screws goes through the plate and the subframe,
the other four goes through the skid plate and the under body panels.
Installation is easy. But I'd recommend getting another set of hands to hold the plate in place while you bolt in in.
The plate does look like its meant to take a beating. Very well built and perfect fit.
snow broke said:
Just put the Roest on my 2012 XTX....Easy install...quality of the plate and fasteners is awesome!
Looks like I'm going to have to buy it for my '12...
Groomer08 said:
i did skinz float plate and debured the stock stiffeners so they couldnt cut my oil filter.
factory they would almost cut your fingers.
I did the same thing, except ground down the stiffeners just over the filter all together for a flat surface. Still holding up great!
