2011 Nytro SE 153 Slides???
quadtrac
Glencoe, Mn
Looking to change slides on my 11 nytro SE 153 and the dealer says its a different part number from the 08-10 sleds? Is that true? THanks
That might be very true.
I installed a set of 2008 153" slides on my 2012" 153 skid, and they where approximately 10 cm's too short..
The 09 and 10+ rails are really different. The arc on the tipped up section of the rails is super long on the 10 and newer SE MTX, so I would suspect it has shorter hyfax as per Dimebag's comments. I just measured my 11 MTX and the hyfax is approx 1540mm's which is a hair longer than 5 feet.
OTM
I agree. I do not know about the 153", but the FX Nytro 162" (2010-) hyfax are actually longer than the Apex 162" (-2010) hyfax. I found out because my dealer accidentaly gave me a set of the SMA part numbered hyfax that just says 162" in the part name. These turned out to be a little bit shorter than the standard 8HA part numbered hyfax found in the FX Nytro 162" part fiche.
