2011 Yamaha Apex SE Excessive Slider Wear
PP offset kit
IH8CROWS said:
When I called pioneer he said they do not make a kit yet for the 2011 or newer, but was in the process of doing so.
So the excell wheels are what you need to look into or like some mentioned.. Doo wheels.
Got a kit from PP for 2011 SE and that was in Jan 2011...did have to use washer to make it work.....had excessive wear prior to installing but very little now...I added extra wheel using take off bracket
I have had the Polaris wheels on mine for 5500 miles.They help a little but you will still burn the stock slides down.I put the Duponts on for the last 1000 miles of the season with zero wear.I did a few speed runs on glare ice the last day out, and there was no sign of heat or wear.
