2012 apex se
raginyamaha
Waterford, wi
2013 xtx
Dad just purchased one and am wondering what updates i should try to sell him. How have the mega floats been holding up, i saw a few that would bleed down. Any input from the 2011 guys would be great.
No issues with my floats, have not checked the pressure but they appear to be up as usual. Measured the sway bar, it is 12mm stock. I had to drop pressures quite a bit from recommended to get it to handle to my liking. Had a set of USI skis that I put on,no experience with stockers.
Ulmer racing has a pump that you can adjust the megafloat from your dash rather then hooking up the hand pump under the skid.
I am swapping his triple threats to this one too. might go a lil more agressive with the fins w power steering now
MR. pro116 could you tell me more about the ulmer pump they sell. that would be really good set up. I ride all diff. types of trails and it is hard sometimes to dig out the snow and ice to get to air valve. I have a2011 se, love the sled. thanks
When installing the triple threats you will need to modify the rubber, or possibly USI has one available by now. I talked to them about what I did last year and they told me they would come up with something. All I did was add a square spacer under the Yamaha spacer, about 3/8 thick. I screwed it tot he bottom of the stock rubber. You need to use the stock rubber as it has a cutout for the spindle that protrudes into the ski mount area.
I think it mounts a little diffrently now.
http://www.ty4stroke.com/viewtopic.php? ... light=pump
good to know thanks... havent checked on website yet or anything
