FingerLakesRX1
Just bought an 2012 Apex Se With the fox floats. Just wondering what I can do asides for pumping my shocks to beef up my suspension. I’m about 320 without my gear.
Revalve it or get a different shock.. really not many options.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Before I spent any Money I would just pump them up and try as the air is an adjustable spring rate. Lots of big guys out there on Apex’s seem to be doing well.
That shock is a pile of crap.. it will never hold the weight and even worse it will take him an 8 hour day to fill it with a hand pump.
yamadoo
- Jun 3, 2003
Oh I never knew that they were that bad. Are they worse than the Viper Fox air shocks? I wasn’t aware they were that bad.
Yes, they suck.
i tend to only check the air in mine once a season on the singleshot as it does take almost 30 min for me to get up to the pressure i need. still not sold on how this suspension behaves as my 11 rides and handles much better for how i ride.
not even close to the same suspension.
i know. got it riding good atm (thanks btw) but struggling to get it to transfer.
The SE is a Mega Float.. and they are not good. Most change them out unless your 180lbs or less
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I have a mono shock in the classifies for cheap ! Add a re valve and Barn of parts dual rate Big Boy spring and you should have a better setup !
https://ty4stroke.com/threads/f-s-shocks.158379/#post-1533957
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I had a mega float in a 06 rtx and liked it after the HyGear volume Spacer and revalve. Also put the dual chambers on the fronts. Had I working good and I weigh 320 too
