cw xtx 1.75
- Jun 12, 2014
- 2013 Yamaha Nytro xtx 1.75
So i installed a LE 2.5 pivot riser , my throttle cable seems tight but when running on the stand and turning the bars side to side the throttle stays the same and does not jump . My ? is have others had to re route there cable ? Put a MTX cable on ? My sled is a 2013 xtx . Also if i were to put a relocate on of some sort would i need a new cable then ? Could i keep my 2.5 and add a relocate ?
Can you route the cable under instead of over to the throttle block?
I have a lake effects 2.5 riser and the oft relocater on a 09. Throttle cable is routed on the back side of the bars. I have had no throttle related issues.
bmazbnytro
Ditto, I have a ROX 3" pivot riser and relocate with no trouble. Did relocate cable though but I don't remember where. I just moved it around until it worked the best. I did have to lengthen the adjustment on the cable.
