Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
What are you guys doing to stop darting? i though i saw somewhere someone likes the stock skis with snow trackers? i am planning to go to new curve skis but don't have the money for new skis yet.
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
Stock skis with 6" DoubleDowns or Slim Jims will get rid of any darting. Since you have an ltx and if you are studded you might want to go 8". I have a studded rtx and run the 6" DoubleDowns. Love em...
Dirtbikekid1998
- Mar 3, 2013
- Maine
How bad is the push in corners? I had duallys a on my apex but they pushed really bad.Stock skis with 6" DoubleDowns or Slim Jims will get rid of any darting. Since you have an ltx and if you are studded you might want to go 8". I have a studded rtx and run the 6" DoubleDowns. Love em...
klondike22
- Mar 4, 2013
- northern New York
- 15 SR Viper LTX SE
My 14 Viper LTX has no studs (yet) I immediately put 6" dually woody's runners on- I have no darting at all. Solid. The front goes where it is told except in deep soft snow. Love this sled!!
MCApex44
- Mar 30, 2006
I find them to be far better than the standard duallys. Compare the difference of the two on woodys website. I find they do get a little harry in the corners on a fresh groomed trails but most anything does. On anything hard pack or set-up trails they rail. I ride aggressive and have no problems at all.
larrypolaris
When I ran stock ski's last year. I used Woody's 6" dually's. Virtually zero darting.
Sled tracked very well. But did have a fair amount of push in the corners.
Floated like a submarine.
I am currently runny Curve ski's. Great ski's. I did have some darting with the 6" carbides.
I installed the 4" leading edge. Ski's track well. Corner great. Float real nice in the deep fluff.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
I have Curve skis on my 2014 ltx, turns much better than stock, but does dart.Did the leading edge make much of a difference?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Shim your skis---easy and cheap. Mine does not dart but does some " following " when following certain ski types. I don't think this is avoidable in all situations.
Shimming works great. Most ski carbide combos on this chassis will wear the front of the carbide more due to the way it sits. Obviously you want to check ski alignment and suspension setup first. Shim the skis and you can run about any ski carbide combo without darting.
Blue Leader
- Aug 11, 2014
- ohio
- 2014 Viper LTX SE
curves are the icing on the cake for this sled!!! 4" round bar if not studded. The LE will stop any darting but not needed
BTbt
- Apr 11, 2005
- Kettleby, Ontario
Alignment is good, I shimmed the skis two weeks ago, better but still follows other ski groves at times, I will put up with this to get the better steering from the curve skis.
Dirtbikekid1998
- Mar 3, 2013
- Maine
What model curves are you using? and how do they do off trail? not looking for a mountain ski but not the stock submarines.
Blue Leader
- Aug 11, 2014
- ohio
- 2014 Viper LTX SE
standard curves work great everywhere
BTbt
- Apr 11, 2005
- Kettleby, Ontario
Curves XS big improvement over stock, better floatation
larrypolaris
I first ran the Curve's with the stock 4" carbide. There was some darting but not that bad.
After the 4" carbides wore out in installed 6" carbide.
The sled darted more then I liked with the 6" carbides. Especially when they were new.
As they wore the darting was reduced but still more then I liked.
I installed the 4" leading edge and the skis track very well. Very minimal darting.
So yes the leading edged helped.
My ski's are toed out ~1/2-5/8 ".
