1moretime
thanks for clarifying! guess i am good!
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
I found this problem with wheeling and long climbs on a steep slope..... The bold lettering could have been a by-product of my cutting and pasting the text
Bet that shorter screen and baffle prevents the pump from air locking when tipped on right side. Heck I see guys carve as far over as I had mine when it air locked and dumped oil! Sure would miss my site glass though.
yukon yamaha
- Jan 30, 2008
I can look the price up later today, I don't think it was very much thou. Should be under 200
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
I have a 15 with the updated tank and I still have problems climbing hills and rolling my sled over and not priming. So I'm gonna say this didn't fix the problem.
stingray719
I am hoping somebody would do the MPI return to engine instead of oil tank and see if it fixes it for N/A sleds too. I VOTE CANNONDALE! lol
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Both of our sleds have the return to engine for the air/oil sep box and that part works great if that's what you are talking about?
stingray719
What do you mean n/a sleds? Both of our sleds have the return to engine for of air oil sep box and that part works great if that's what you are talking about?
Yes, was wondering if anybody has tried it on a Naturally Aspirated Viper.
yamahaguy
Ride SAFE
- Apr 20, 2014
Sure it work work. I know snoninja is adding one.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Simple concept. Get rid of the return line from the oil air separator to the bottom of the oil tank, and return to the engine instead. When you tip the sled, it is the residual oil that is always in the return line that ends up in the air box and makes a mosquito foggier out of the viper. The return line does not have a backflow preventer in it so the oil in the line backflows into the separator and then air box when you tip the sled. Seperator still breaths to air box, but returns to mag side of engine instead. Maybe MPI can chime in on the application to NA vipers as he developed the plumbing mod. I know a lot of NA guys would do this if they knew it worked.What do you mean n/a sleds? Both of our sleds have the return to engine for of air oil sep box and that part works great if that's what you are talking about?
I would but would need to know the effect it has on crank case pressure or if it's the same. Most 4strokes have pressure. Yamaha does not. It supposedly assist longevity and ring seal because the Pistons don't rock as much as when under pressure.
http://snowmobiles.yamahablogs.ca/wp-content/uploads/2015/04/Engines-Dont-Just-Happen.pdf
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Hence the need for input from the designer. I would expect that this was considered in the design, but only MPI can tell us that for sure. Not sure though why it would work for the turbo and not for NA. Oil plumbing is the same whether turbo'd or not, or am I missing something?I would but would need to know the effect it has on crank case pressure or if it's the same. Most 4strokes have pressure. Yamaha does not. It supposedly assist longevity and ring seal because the Pistons don't rock as much as when under pressure.
For $25, I would like to keep oil out of the air box, but motor longevity is priceless.
Does anyone know if the MPI trail turbo is coming with this plumbing mod?
yamahaguy
Ride SAFE
- Apr 20, 2014
Originally this mod did not come with the turbo kit but MPI sent them for free to anyone who purchased a turbo last year to the dealer where your turbo was originally sent to. This year its supposed to be part of the kit. When I spoke to MPI last year while they were testing this mod in R&D they told me a stock sled would start spilling oil into the air intake around 30 degrees and after the mod it didn't spill oil until about 80 degrees. I can tell you that we used to spill oil all the time into the air intake but after the mod its been a non issue and our sleds are on the side all the time ( those are called random carbide/ski bottom inspections )
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
How do you tell if you dealer installed the oil line plumbing mod? My dad ordered his kit in October of last year but didn't get it until February and they installed it in February.
yamahaguy
Ride SAFE
- Apr 20, 2014
Look behind the Muffler at the mag cover. If its installed you will see 2 lines going to the side of the mag cover. One line for the turbo oil return, one line for the air/oil return.
- 9K
