fasteddie15x
- Jan 20, 2014
After removing my seat, fuel tank and clutches, i was able to find that the front heat exchanger was leaking from a weld. Has anyone replaced this before? If so do you have any advice on how to remove it, I would appreciate it, it looks like a big job.
I never did but have replaced tunnel. Exchanger is bigger job. Just start drilling rivets. Leave at least a day to remove and replace.
fasteddie15x
- Jan 20, 2014
Thanks for the advice. The sled is actually my father inlaws and he decided to take is to a yamaha dealer.I never did but have replaced tunnel. Exchanger is bigger job. Just start drilling rivets. Leave at least a day to remove and replace.
Mikaaleeraq
- Jan 22, 2026
- Narsaq
- Other
- Yamaha sr viper
Have u replaced it yet? I think mine is leaking from the same place, and i was wondering if i have to take the engine out to replace the heat exchangerAfter removing my seat, fuel tank and clutches, i was able to find that the front heat exchanger was leaking from a weld. Has anyone replaced this before? If so do you have any advice on how to remove it, I would appreciate it, it looks like a big job.
Its about a 8hr job first time. Comes out bottom. have to remove everything attached to it and everything in the way along with drill and reinstall rivets. New ones are about $650 never found a welder that would try fixing the cracked weld on left side.
