papa
- Feb 8, 2009
- woodstock nb
- 2014 apex xtx
hi up here in n.b. i have a 2018 rs venture tf and when you start it when it is cold it does not want to stay running unless you play with the throttle but once it gets warmed up its ok should also say when it stalls when it is cold you have to give it some throttle for it to start or it just kicks changed the spark plugs today same thing put 110 miles on it on sunday stalled once at a stop sign but started right up worked great all day it has been doing this for the last 2 weeks any ideas
sounding like iac might be plugged. no other issues? how many miles/km on the sled.
papa
- Feb 8, 2009
- woodstock nb
- 2014 apex xtx
the sled has 12000 kilometers on it the dealership in fredericton said to clean the idle control valve as i did that tonight but is still the same the sled is my brothers and the vavle looked clean when i took it apart but i cleaned it anyway stumped.
have you ever run seafoam in the sled? might have some sticky injectors.
something else to try would be start the sled with the belt off when cold to see if the clutch is sticking. if it starts up with belt off without needing to play with the throttle, odds are that is the issue.
papa
- Feb 8, 2009
- woodstock nb
- 2014 apex xtx
when i said i cleaned the idle control valve i cleaned the throttle positioning sensor as the dealer told me that was it found out later he was the service manager and the next time i called i got to talk to a mechanic and he said it was on top of the fuel injection system and then added that is where it is located on the sidewinders but it is not on this do you no where it is located also we put a bottle of sea foam in it thursday and put 60 miles on it but have not tried to start it today yet as another dealer said to try seafoam as it worked on the apexs over the years sidewinders are 999 cc as the venture is 1049 cc 2 different motors maybe it is in a different spot because it is not on top by the injector on the clutch side as the mechanic told me thankshave you ever run seafoam in the sled? might have some sticky injectors.
SteveBlue
- Nov 23, 2024
- Killarney Manitoba
- 04 Warrior. 07 Phazer Gt. 08 Phazer Mtx. 11 Apex XTX. 18 RS Venture TF.
I have the same machine and same issues. Do I post here?when i said i cleaned the idle control valve i cleaned the throttle positioning sensor as the dealer told me that was it found out later he was the service manager and the next time i called i got to talk to a mechanic and he said it was on top of the fuel injection system and then added that is where it is located on the sidewinders but it is not on this do you no where it is located also we put a bottle of sea foam in it thursday and put 60 miles on it but have not tried to start it today yet as another dealer said to try seafoam as it worked on the apexs over the years sidewinders are 999 cc as the venture is 1049 cc 2 different motors maybe it is in a different spot because it is not on top by the injector on the clutch side as the mechanic told me thanks
yesI have the same machine and same issues. Do I post here?
SteveBlue
- Nov 23, 2024
I got the machine last year. I first noticed it would stall at idle after it warmed up, so I shimmed the valves and replaced the timing chain; 18000km. This much improved the idle but it still surges slightly at idle and has a cold starting quirk. It will start and stall 4 or 5 times and seems to not be using its elevated cold idle speed. Then it will decide to use elevated idle and its good for the day. It's a ycct electronic throttle and I'm suspicious the ycct needs adjustment or testing to cure surging and the cold start. It does not have an Iac valve. Does anyone have knowledge of ycct system tests or settings. 16+ vectors i think would be the same. The gauge does not allow me into diagnostic mode.(too new I think) Thoughts?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The computer controlled throttle does the idle.
I had tight valves on my 16 Vector that cured my cold start idle problem. Been good ever since.
Could possibly be sticking throttle plate but I would add some sea foam for a couple of tanks of fuel and run it. Let the injectors clean out.
SteveBlue
- Nov 23, 2024
The potions don't seem to work. Does anyone know about adjusting the cct system?The computer controlled throttle does the idle.
