blake
I have a question about the rear springs I weight about 260 without gear and im wondering if I have to find a set of heavy duty torsional springs. I had to do that on my nytro xtx. does anyone know if anyone makes them. my dealer told me there was none available for my sled
anyone else have this problem
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
I weigh the same and I put the billet adjusters from the accessories catalogue. ettOn the third setting it should be good, there is a fourth setting if you need more. Easy to install.I have a question about the rear springs I weight about 260 without gear and im wondering if I have to find a set of heavy duty torsional springs. I had to do that on my nytro xtx. does anyone know if anyone makes them. my dealer told me there was none available for my sled
blake
cant find them anywhere on the site seems the site changes every weekI weigh the same and I put the billet adjusters from the accessories catalogue. ettOn the third setting it should be good, there is a fourth setting if you need more. Easy to install.
blake
that is why I couldn't find them don't have them listed under a sidewinder only a viper will they fit the sidewinder with no problems
Chris Rose
- Jul 29, 2016
- Powassan ONT
The part number is SMA-8JP39-BL-00 for the blocks, also 2 of 8JM-RA315-00-00, retainer springs.I weigh the same and I put the billet adjusters from the accessories catalogue. ettOn the third setting it should be good, there is a fourth setting if you need more. Easy to install.
awolb69
Go with the billet adjusters as others have said here, but you may just want to ride it first with the stock springs and adjusters. I'm about 235-240ish lbs without gear and I rode my XTX 137 Winder last year without any bottoming issues at all. Stock adjusters were set in middle position. I have the gray/yellow '18 XTX 137 coming in soon and will set it up the same.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
I have the xtx Le 137 and am 280 lbs no gear, also added the 3.5 gallon BRP gas can to rear tunnel , the first 1500 kms rode with rear spring on Medium setting and shock on soft setting, sled rode and handled the weight great and at 1500 km mark I set the shock to the medium or number 2 setting as the suspension was starting to loosen up and I have not had a bottoming issue at all and now the sled is just over 1800 km. I'm very impressed with the weight carrying capacity of the rear suspension. I recommend driving it before making any component changes in the rear suspension . Just my thoughts and enjoy your new sled
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I think these sleds are sprung quite stiff out back. And that has alot to do with the poor transfer, and also creates more over heating situations when the flap is too high off the ground.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I'm 200lbs and run my rear springs on the softest setting. 2017 xtx 137. Have not bottomed out the rear end at all.
Jason Almeida
- Dec 6, 2019
- Brantford
- 2018 sidewinder Ltd se
Should I use this billet adjuster or just replace
The spring with a heavier one?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
billet adjuster under $100 .Should I use this billet adjuster or just replace
New heavy duty spring $400+/-.
Try the adjuster , many have , with good results .
Jason Almeida
- Dec 6, 2019
- Brantford
It won't damage the spring? Sorry for the stupid questions but I'm really new to this. Thanks
kalakauppias
- Dec 21, 2010
Buy 2015 LTX Viper rear springs, those are stiffer at the end but less preload.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
No it will not damage the spring.It won't damage the spring? Sorry for the stupid questions but I'm really new to this. Thanks
