Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
Will the trottle body wire fit with the BOP trottle lever?
Throttle body cable ball-end fits fine in the pocket for the BOP/Apex lever.
Haven't checked on cable tension/slack if it has changed due to the BOP lever, haven't heard that it is an issue so far.
Fleecer
- Jun 13, 2014
- 2019 SRX
No issues here....plug it in, bolt it up and flawless.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
ThanksThrottle body cable ball-end fits fine in the pocket for the BOP/Apex lever.
Will it work with an 8 inch riser?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Got to finally look harder at a '19(cat 8000) and really like the new brake lever, switches, and throttle lever is very similar to the japan throttle I have, feels great. Too bad SRXs have been delayed into December, Dealer is not too happy with YAM at this point.
Dan
Dan
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
My wife just loves the throttle and brake on her 19 zr6000! She hated the set up on her zr7000!She always complained that her throttle and brake leaver were too far away!Got to finally look harder at a '19(cat 8000) and really like the new brake lever, switches, and throttle lever is very similar to the japan throttle I have, feels great. Too bad SRXs have been delayed into December, Dealer is not too happy with YAM at this point.
Dan
I also much prefer the set up on my 19 zr9000 vs my viper
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyone try putting the 19 lever yet? I can’t see why it wouldn’t work.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
the 19+ lever only has one circuit while 14-18 has two circuits. Different circuit logic
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Yeah one heating circuit so you could wire it and basically have it on off. I typically don’t even use the thumb warmer anyway. Anyone know the resistance of the element? If it’s similar to the high low it should work.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Looks like 40ohms.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Could somebody post a picture of the backside of the 19 throttle lever. Thx
