19sidewinder
- Feb 9, 2021
- new brunswick
- 19 yamaha sidewinder
No prob I’m at a complete loss I took off all performance parts removed tuned and taking it to dealerOk. Manual is wrong. Wouldn't be first time.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Did you turn the engine backwards and jump cam timing?
Did you blow a belt and spit out a valve shim?
19sidewinder
- Feb 9, 2021
- new brunswick
Nope and I removed valve cover and checked timing it was goodDid you turn the engine backwards and jump cam timing?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Swap injectors from one cylinder to another and see if the dead cylinder follows. May be a bad injector.
- 6K
