19sidewinder
- Feb 9, 2021
- new brunswick
- 19 yamaha sidewinder
12.4ohms across each injector and nope only have done a leak down testOK. Coils are good and wiring to connector is good. Since you said you tried new plugs, I would deduce ignition is not the issue.
I've not seen a sled idle w 13.7 volts. Is battery good? Load test?
So next I'd test fuel injector. Spec is 86.4 - 105.6 ohms across the two terminals.
Have you done a compression test?
19sidewinder
- Feb 9, 2021
- new brunswick
It actually acts worse when up to temp and it’s running voltage from 13.7 to 14.2vDoes it still behave this way when it's up to temperature ?
What is the voltage output when running ?
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
You mentioned you upgraded your fuel pump, have you tested your fuel pressure?
19sidewinder
- Feb 9, 2021
- new brunswick
It has a fuel pressure regulator on it fuel pressure is set at 48lbsYou mentioned you upgraded your fuel pump, have you tested your fuel pressure?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Verify fuel pressure , those gauges are known to be out to lunch
vmxrdr
- Feb 3, 2012
We chased a weird misfire and it ended up being the gap 3 bar sensor, your miss might be more specific though. We had another sensor to try which made diagnosis super simple though.
19sidewinder
- Feb 9, 2021
- new brunswick
Tried new 3 bar it didn’t helpWe chased a weird misfire and it ended up being the gap 3 bar sensor, your miss might be more specific though. We had another sensor to try which made diagnosis super simple though.
If you haven't already, put the OEM coils back in.
19sidewinder
- Feb 9, 2021
- new brunswick
Tried it replaced all 3If you haven't already, put the OEM coils back in.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Check for codes using the flasher tool?
19sidewinder
- Feb 9, 2021
- new brunswick
No codesCheck for codes using the flasher tool?
Turboflash
- Mar 18, 2019
- Southern MN
You state injectors are 12.4 ohms?12.4ohms across each injector and nope only have done a leak down test
Service Manual shows resistance of 86.4 - 105.6 ohms.
19sidewinder
- Feb 9, 2021
- new brunswick
Yu
Yup I tested all 3 at 12.4ohms is it possible all 3 went bad at once?You state injectors are 12.4 ohms?
19sidewinder
- Feb 9, 2021
- new brunswick
I tested my buddies injectors as well they were 11.8ohmsYu
Turboflash
- Mar 18, 2019
- Southern MN
Ok. Manual is wrong. Wouldn't be first time.
- 6K
