mshabaz
- Aug 16, 2006
Hi guys. I have an 06 apex gt that I put the 23 tooth top gear on and love it. I have a 2011 se now as well. Does it need the 23. Tooth gear as well. Not sure what comes in it. I'll do it if it will make it more punchy!!!
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
The 128's have a 24, the xtx has a 23.
mshabaz
- Aug 16, 2006
So has anyone put the 23 in like we used to to on the older apex's?
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
23 is a common gear swap since you don't need to buy a new chain. There was an Apex gearing thread last year that was helpful to me as it had comments on several different set ups. (However, I cannot locate it at the moment). I ultimately went with a 24/39 gear. It helped my midrange, however I'm now spinning 11k RPM's WOT, so I need a little clutch weight to bring it down to 10,800.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
chadman
What will happen if I go to a 24 37 stock gears on my 128 vs going to a 23 37? I am also going to stretch it to a 136 for next year so I know that will change things. I did not get to much from that thread because everyone was all over the place and did not specify what kind of riding they did, trail riding whith the need for some top end or just plain lake running where you need all the top end you can get. I also trail ride and there is not alot of places that I can top end my apex. So what would be the best setup for this situation?
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
Your 2011 apex should have 24/37 as stock configuration. Unfortunately I do not have any experience with a 136 set up, so I don't want to comment on that and potentially provide bad information.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
X 2. 24/37 is stock.
With a 136 I'd go to a 24/38 or a 23/37.
mshabaz
- Aug 16, 2006
I did the 23 tooth on my 06 and was super happy. Mid range is much better and I actually picked up top end cause its much easier for the engine to pull. So I think I wil go ahead with the swap on the se and see how it goes
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Interested to hear the results once you do.
sx7001
- Jun 28, 2003
- Sidewinder
I can tell you the 23/37 combo in my 12 XTX is bad a$$...
mshabaz
- Aug 16, 2006
Same set up in my 06. And yes. Bad a$$ is right. That's the way I want my se to be
chadman
I am going to go with the 23 also. Thanks for the info everyone.
tube
Put the gearing back to stock and run 66g polaris weights and pins grind the tips just a but so they clear with a yamaha orange primary spring and 3 washers cut 30 thou. off the primary sheaves run a shock wave helix with 60 thou. cut off the end 1 turn out and a black yellow spring and hang on best clutch kit ever this apex rocks runs 10800-11000 depending on conditions ----2006 Apex GTSame set up in my 06. And yes. Bad a$$ is right. That's the way I want my se to be
