rcguy
2008 Nytro with air box removed and running 3 seperate filters...
Does anyone know of a nitrous system that will work with this? Is it possible to run a wet system with the fuel or is spraying the best way to go?
Any help would be great, Thanks
- Apr 14, 2003
- Hessel, Michigan
With the filters, you will need 3 nozzles, or if you can figure out a way to have 1 nozzle and plumb into all 3, that would be the ticket.
I have always used nozzles in the airbox and fogged the airbox.
rcguy
Ok, im not going to try and act like I know what I'm talking about because really im totally new to nitrous..
if running 3 nozzles what nozzle size would I need to run roughly 10-15hp per cylinder
and is there any online stores that sell parts like lines and solenoids and tanks and everything seperatley so a guy can make his own system?
It crossed my mind to plumb all 3 into 1 but I was worried about even distribution..
any ideas and help is greatly appreciated
With a Nitrous Express wet system for 10 per hole you need a 18 NOS and a 16 fuel, for 15 per hole you need a 20 NOS and a 18 fuel.
Bruce
Bruce
rcguy
Thank you,
just another question, i know when running dry nitrous you need to add more fuel by using a programmer
so if your running the nitrous through the fuel with a wet system and trying to add more fuel to compensate wouldnt you be adding more nitrous at the same time?
again, thank you for your patience with a nitrous newby. its greatly appreciated.
rcguy
Thanks for the help guys, I have come to a decision and will be running a Boss Nos setup.
