wifarmboy
- Jan 12, 2012
I drove my sled in the shop to check it over fixed so little stuff went to pull it out I had 4 engine codes 13-15-25-84. The sled will start but as soon as you touch the throttle it dies. Looked on line couldn't find much useful info. I got into the diagnostic screen and the 01 screen which should be the tps range only goes 1-3 so I'm thinking its the tps correct? I just don't want to wait 3 days for a part that doesn't fix it. There calling for 9 in. Today and tomorrow then 50 by the weekend so any info one way or the other would be appreciated. Also I went to the local sled yard and tried a tps off a 06 apex just because it was sitting there and I got the same 1-3 range I'm not sure
Thanks guys
Thanks guys
tk77
i don't know codes but, a sled that starts and idles and shuts off when the thottle is touched sounds like an Throttle Over Ride Switch issue to me.
Ffbsy
codes
did you check the wiring behind the primary were it rubs on a little casting nub on all nytro's? I would start there if you haven't already.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Sounds like the Tors.
Disconnect it and install a tether. Or adjust the throttle slack to specification.
Dodge Ram
tk77 said:i don't know codes but, a sled that starts and idles and shuts off when the thottle is touched sounds like an Throttle Over Ride Switch issue to me.
X2
