4 codes and won't run. I hate wiring
wifarmboy
I drove my sled in the shop to check it over fixed so little stuff went to pull it out I had 4 engine codes 13-15-25-84. The sled will start but as soon as you touch the throttle it dies. Looked on line couldn't find much useful info. I got into the diagnostic screen and the 01 screen which should be the tps range only goes 1-3 so I'm thinking its the tps correct? I just don't want to wait 3 days for a part that doesn't fix it. There calling for 9 in. Today and tomorrow then 50 by the weekend so any info one way or the other would be appreciated. Also I went to the local sled yard and tried a tps off a 06 apex just because it was sitting there and I got the same 1-3 range I'm not sure
Thanks guys
by pass the tors plug white into black and black into white wires by headlight single black single whit if it still does not run right it is not tors
