bolognarx1
where is the cheapest place to buy the Fourth wheel kit for my Attak?
i just make it myself cutting the exsiting long spacer
Super Sled
- Feb 25, 2009
- Summit X
spddmon said:i just make it myself cutting the exsiting long spacer
Pics please of what you did! ;-)
you have all the peices already. took us about 20min with assembly on my dad's venture. the short tube between the rail and existing 3rd wheel gives you the 1st dimension for the 1st cut. then you subtract the width of the bearing in the wheel for the second cut. i reccomend cutting with a band saw or a chop saw but it can be done with a grinder. then just re-assemble.
02xtreme
I am just about to do this. Like the post above says, if you have a spare wheel just cut the existing tube.
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
If you don't have a spare wheel, you can get a wheel for @$16.00 or a 4th wheel kit for @$31.00. Yamahasportsplaza.com. Portyamaha, is a couple bucks higher. business with advertisers is good. Also pioneer performance has this $39.95
