yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
After beefing up my suspension, I'm almost ready to install the skid back into my Attak. I have also just installed a brand new Rip II track. I see some guys have the fourth wheel kit so I searched it on here. Some say it is a waste of time while others say it will save your track if you happen to lose a rear wheel. So I'm curious to see how many guys on here have this and if it is a worth while upgrade. I can do the mod myself, just need the extra wheel. Thanks
Smokum
- Jan 31, 2011
- Prairie du Sac WI
- 2011 Apex XTX, 2003 RX-1 MTN
If you already have the skid out it is cheap insurance if you ask me.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
I have done it on all my sleds, helps the sled roll better,
The fourth wheel is probaly more important when running a studded track. Helps keep it lined up so the story goes.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
My friends RTX outer wheel came off once & if it wasn't for his 4th wheel kit, it would have destroyed his track & probably worse. He drove home no problems. I ordered kit next day...
yama_rider
- Sep 15, 2014
- New Brunswick
- 2009 RS Venture
Nuff said. I have already ordered the extra wheel. From what I gather, I have to make the short spacer 24mm and the bearing is 12mm wide, so I can do the math and make the longer piece to suit. I do plan on studding probably half way through the season when the trails tighten up.. As already mentioned by smokum, its good insurance.
Yamahadj
- Mar 9, 2014
- West Michigan
- 2006 Apex GT
I added it as well when I had my suspension out. Can't hurt. Like others have said, if you loose either outer wheel, you can still get back.
