Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Re: Warranty
Ahhhhhh yes, the old double seal trick is real good at making large messes, isn't it!
Butta said:Big note, however, ensure you get the sealing ring off the motor from the old filter!! Mine, and others, were stuck. Had I not known to look, I would most likely have tried to put the new filter on top of it.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Re: Warranty
Welcome to the site
BriKielyGSMan said:I have read somewhere before that there is a clause (law) of some sort stating that warranty will not be void if you do the maintanence yourself. As long as you can prove that it was done when required and that you were capable of doing it.
I think it (the clause) was some guys name ..........not the Murphy's Law one either.
I plan on maintaining the Nytro myself.
Anyway, hello to all fellow sledders ......
Welcome to the site
hollyjason1977
SIKEWARD said:I used wix filter and mobil 1 ow-30 full synthetic for my 500 mile service. I have to admit I did the service a little premature the sled was torn apart because of a bent sub frame at 380 miles so I changed it while it was apart.
I can not find Mobil1 0w-30 will 0w-40 work?
eddietcat01
Re: Warranty
Been there, done that. Not proud of it either.Crewchief47 said:Butta said:Big note, however, ensure you get the sealing ring off the motor from the old filter!! Mine, and others, were stuck. Had I not known to look, I would most likely have tried to put the new filter on top of it.
Ahhhhhh yes, the old double seal trick is real good at making large messes, isn't it!![]()
