7.5 billet wheels
rx1 fern
thompson mb
hi can you put 7.5 billet wheels on the stock back axle of a 2004 rx1 with the proaction.what is the stock back wheel size .will it work if i changed all the 3 back wheels to a 7.5 and used the stock axle is what i need to know .thanks for any help.
Yes you can. Stock is 7 1/8" new and 7" worn and used. you would only be 3/8 larger in diameter. The added depth of you wheel would then be 3/16 lower to aid in your slide wear. Change out your other smaller wheels for 5 3/8 or metriccly the 5.35 wheels from excell and your good to go. Cheers, Scott
thanks for the reply scott32 .i recieved the wheels yesterday.just have to get bearings for them now.
also do i need the washers for the billet wheels that yamaha sells for their billet wheels.thanks
That I am unsure of as I am not familiar with the wheels your using. The bearing that will be used will most likely determine what you need to do, to make it work. Whatever you do just make sure that your new billets line up properly, as did your stock wheels. If the bearing your using in the billets is the same bearing as stock, everything inbetween should be the same. Good luck and Cheers, Scott
