Xrx1dude
- Dec 1, 2017
- Thornton NH
- 2007 attakgt
Having bought a 2018 XTX the end of last season I am now reading through the owners manual and noticed it wants 91 octane as a minimum. My 07 Attakgt 87 was acceptable. What has changed? Compression ratio? Ignition timing?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Timing has changed 100%, not sure about compression. If you run 87 octane the knock sensor will start pulling timing and you’ll lose out on some performance.
i have run my 11 on 87 when no 91 availible. ran fine but i made sure i did no wot pulls on it. i have noticed on my wr250x that when i had to run a tank of 87 though it that it ran hotter than on the 91 and was not as peppy. it only wants 91 as well.
Fleecer
- Jun 13, 2014
- 2019 SRX
It will run fine on 87, but will turn 500 rpm less at WOT, which will yield 6 mph less top end speed. If you're OK with that, then running 87 is fine!Having bought a 2018 XTX the end of last season I am now reading through the owners manual and noticed it wants 91 octane as a minimum. My 07 Attakgt 87 was acceptable. What has changed? Compression ratio? Ignition timing?
Xrx1dude
- Dec 1, 2017
- Thornton NH
- 2007 attakgt
Definitely not okay with that! LolIt will run fine on 87, but will turn 500 rpm less at WOT, which will yield 6 mph less top end speed. If you're OK with that, then running 87 is fine!
Kevlar55
- Feb 15, 2004
- Western Mass.
- 07 Attak.
This is whats on my 07 ATTAK.
Oldvolts
- Mar 2, 2020
- Eastern Maine
- Cats, Moto-ski, Yamaha 2007 Attak
RON is a different unit of measure than what is shown on gas pumps in the US and Canada. Not a lot of difference between 91 RON and our 87 (R&M)/2.
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
Pretty simple, run what it calls for, I always carry a few tubes of octane boost just in case I can't get 91 in more remote area's.
