I took my air box off. I couldn't find the T wrench that Allen showed, but found that a ball end allen wrench works fine.
The clips that the pod screws screw into can fall off. If it drops it will be lost forever. I siliconed mine on.
The oil drain cover screws are much improved. No problem.
There is a gold tube with hoses attached under the motor. It will rattle against the bottom skid pan. I put some foam tape on it, so it doesn't wear a leak. I think its a cooling tube.
