BigDog05
If you want to try and ride this sled w/o doing a lot of work right now, I would suggest the following.
Get rid of the boost switches. Just run one hose from the turbo to the wastegate canister.Take the clip off the canister where the rod goes to the wastegate. Adjust the rod so it just slips on the connection and the wastegate is fully closed, then shorten the rod about 1/8-1/4 inch so it takes a little pressure to hock up. This keeps it from fluttering and will gve you around 6-7 lbs boost.
Get a wideband air guel gauge.
Make sure the exhaust is not slipping where it connects back by the turbo.
Get it dialed in with 93-94 octane and then you can determine what direction you want to go.
Check and see if the carb tee's are black and glued on, or metal.
