My friend bought an 08 FX Nytro and on the bottom of the airbox there is a little nipple that has NOTHING attached to it and oil is coming out. My question is: should something be there (like a vaccum line) and if so, where does it go to, or is it a drain hole.
Any pic's would be appreciated.
yamaha06
rcp1018 said:My friend bought an 08 FX Nytro and on the bottom of the airbox there is a little nipple that has NOTHING attached to it and oil is coming out. My question is: should something be there (like a vaccum line) and if so, where does it go to, or is it a drain hole.
I'm pretty sure that's just a drain hole? And the oil spitting out would probably be from someone previously filling the oil tank to full which causes oil to be puked out into the airbox!
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Or tipping sled on its side can cause that if it does have a rollover protection valve.
Nine2Nine
Any aggressive riding will dump oil into the air box, normal and acts as Rust Proofing!!!!
couch
Ha haha ahahaha
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
That is the drain for the airbox.
Clean out the oil and wash your foam filter.
